Home > Faults & Fixes > Overboosting Turbos. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
A crack in the exhaust manifold would cause an underboost fault...
Wed Mar 27 2019 8:18pm |
winston wolf Member Since: 27 Mar 2019 Location: Wiltshire Posts: 4 |
The Turbos were replaced about 4 weeks ago. The garage that replaced them said it was also going into limp mode because of the overboosting. It wasnt going into limp mode before they were replaced. They were recondictioned ones fitted at Best Turbos in Birmingham. The remap and Egr delete was done by previous owner. |
Wed Mar 27 2019 8:24pm |
I suspect the recon turbos are the issue. The electronic actuators cannot be calibrated correctly, other than by the manufacturer. Ideally, you need to check the actual position v commanded positions on the actuators
Wed Mar 27 2019 9:05pm |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 |
Maybe try Midland Turbos. They do all our turbos (TDV6 and TDV8) and can set the actuator correctly to factory settings. Never had any problems with them and never had to set the actuator once fitted to the car.
Thu Mar 28 2019 10:36am |
Many thanks to you both for your imputs.
Thu Mar 28 2019 10:58am |
