![]() | Home > Maintenance & Modifications > Aircon and Megaflush in West Midlands |
I thought 8 speeds took a lot longer due to the thermostatic valve and the cool off time to check level? Visitor from fullfatrr.com
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
Not really. The temp doesn't get any hotter than 50deg and the valve remains open. Joe |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
The thermostatic valve begins to open at 67/68 degrees (ish) and is fully open at 75 degrees |
OK, so maybe I should have said that the procedure takes about 30mins, but the actual job can take up to an hour from ramp on to ramp off without filter change. Add up to another hour for filter change, but…….
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
impressive |
