Rolling in neutral and engine off
Hi all,
As the title suggests really. Has anyone found a way to get the gearbox in an L494 into neutral, with the ignition on but not running the engine.
My drive is on a hill, and it’s often useful to roll cars down it a little to make room for someone else, but without needing to start the engine for 10 seconds to ‘drive’ it the 2 meters I need.
There is a way to disable the gearbox Park lock pawl, but it is only for breakdowns, not a procedure you could use easily.MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Mon Mar 25 2019 9:08pm
Dobby
Thanks, i thought as much. There seems to be either a pull-release sround the gear shift on some models, or either a combination of pressing pedals and flappy paddles on others.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
