Home > Maintenance & Modifications > Egr blanking kit
stevoc
Scotland
Egr blanking kit
Hi team.
Someone posted about the love/hate we have with our RR sports. After owning mine for less than a year I now understand!!!!
Deep pockets was the term used lol. I’ve now spent £2500 already 😩
So know the EML came on and yes it wasn’t a split hose but the egr valves, it just had to be!
My indie guy suggests getting them blanked off as a less expensive option although I will need to get the diagnostic guy on it to clear the light. Can anyone suggest a certain type of kits or are they pretty run of the mill?
Thank you
Post #577211 Sun Mar 17 2019 10:38am
Oldandconfused
EU3 (up to 2005/6?) can just be blanked, but EU4 engines will need a software patch to turn out the EML light on your dash, which I think is an MOT failure if illuminated.
It is now an MOT failure to tamper with emission equipment, your EGR valves, but what most people do is fit the shims blocking the EGR valves, and then refit the original pipes so that it looks like it is all original.
You could replace your EGR valves, probably several hundred quid, or buy the blanking kit for less that £50 and an hours labour at your indi. You can do them yourself if your handy with spanners, there will be a guide her or if not, certainly the Disco3 forum.
If you do delete, best keep quiet about it though.
It might help others to advise you if you fill in your vehicle profile so we know what MY you have Thumbs Up
DM write up on valve replacement;
https://www.disco3.co.uk/forum/egr-valve-3...k%2Bhow+to
OR blanking
Post #577215 Sun Mar 17 2019 11:07am
e.g
https://www.ebay.co.uk/itm/EGR-Blanking-Pl...SwV0RXrK4n
Post #577219 Sun Mar 17 2019 12:05pm
Disco_Mikey
I've always been advised NOT to blank the EGR's on a TDV8...
Post #577222 Sun Mar 17 2019 12:42pm
Sorry. Didn’t know he had a v8
Post #577234 Sun Mar 17 2019 3:39pm
Oldandconfused
Me neither. Just goes to show that DM is psychic Bow down
Post #577237 Sun Mar 17 2019 4:01pm
Disco_Mikey
Only 13 previous posts. Had a quick browse Whistle Wink
Post #577238 Sun Mar 17 2019 4:12pm
stevoc
Scotland
Well thank you guys for the advice,it seems disco mikey is all knowing lol.
I will update my profile so it becomes easier to answer my posts because I do suspect there will be more!!!
So all in all it seems a bad idea to blank off the v8 then?
Post #577250 Sun Mar 17 2019 5:46pm
Disco_Mikey
I was warned of long term issues after blanking on the V8...
Post #577252 Sun Mar 17 2019 6:01pm
SlyBacon
United Kingdom 2007 Range Rover Sport TDV8 HSE Rimini Red
Long term issues?
Post #577272 Sun Mar 17 2019 9:08pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Is it only 2.7's that can be blanked then, not TDV8's or SDV6's ?
Post #577281 Mon Mar 18 2019 7:52am
FYROB
England 2008 Range Rover Sport TDV8 HSE Java Black
i had eml light coming on my TDV8 had it egr terra cleaned which sorted the issue for about a week .(i cleared it with icarsoft)
it then came back on again , so before blanking , i gave both valve shafts a good spray of EGR cleaner , gave the area a bit of a scrub with a small paint brush and a light brushing with copper grease and fitted the blanks . that was about 1000 miles ago , the fuel economy has shot up and car much smoother .
having read this, the ole clacker valve is twitching as is seams the tdv8 shouldnt be blanked , does anyone know why and what the damage it can cause is ?
cheers in advance
Post #578511 Sat Apr 06 2019 2:18pm
Azz3r1989
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Java Black
2010 tdv6 egr blanking
Hello all am new to this forum. Sorry if this has been answered. Looking at doing the blanking myself on my rrs tdv6 2010 l320. Not sure if it needs pluggging in or re mapping etc after or if it doesn’t?
Any help much appreciated
Thanks
Aaron
Post #631558 Sat Mar 11 2023 4:36pm
riverblanche
Hi and welcome,
the second post tells you Whistle a Patch will be required Thumbs Up
have a go with the "Search" button in the orange banner above and you should get lots of posts about it with much more details
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #631560 Sat Mar 11 2023 7:38pm
Azz3r1989
Hello thanks for the quick response.
I have had a search on this and can’t find much regarding the tdv6 3.0 diesel. Most threads are just referring back to the v8’s.
I just would like to to if fitting one would
A/ pass and MOT?
B/ need any software upgrades
C/ or can the kit be fitted without any other issues ie knocking and having the ECU throwing any codes or lights on the dashboard!?
Much appreciated 😁
Post #631562 Sat Mar 11 2023 8:48pm
