![]() | Home > General (L494) > Me again... Oil level. |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1874 ![]() ![]() |
http://www.ownerinfo.landrover.com/documen...c/G1797365
RAW Member Since: 05 Apr 2018 Location: Devon Posts: 55 ![]() |
Oil level can only be checked when engine is at correct temperature and its difficult to calculate whenthat is.
29salcombe Member Since: 08 Jan 2013 Location: Cornwall Posts: 38 ![]() ![]() |
Thank you RAW.
The cruise cancel info wont be in the manual i think as its a trick they use in the service bay, i will try and find a link for more info MY18 RRS Autobiography Fuji White
Hope this opens ok
Can you access the "service menu" while driving? |
No oil level can not be done with engine running MY18 RRS Autobiography Fuji White
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 781 ![]() ![]() ![]() |
Don't think you left it long enough after turning the engine off before you checked, or the oil wasn't hot enough. I did exactly the same the other day, give it a few more minutes and it should give you a reading. |
From the online manual
