Home > Technical > Hesitation between gears
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi all,
Got my RRS last week and I have not had an automatic before so need a little advice if this is normal.
My question is that when I'm driving along the road, I accelerate, the car hesitates. It feels like it can't decide on what gear to go in. The revs which are around 2000rpm go up and down quite a bit and it is slightly hesitant and jerky and doesn't feel smooth.
Like I say, I've not had an automatic before and I am wondering if this is normal. Any help would be much appreciated
Thanks in advance.
Post #435782 Tue Sep 09 2014 2:22pm
Bungleaio
2005 Range Rover Sport Supercharged Buckingham Blue
No that's not normal. How many miles has it done? Has the gearbox oil been changed recently?
Post #435783 Tue Sep 09 2014 2:45pm
Bodsy
Site Sponsor
sounds like the torque converter may be on its way out... try a transmission fluid change and maybe a pouch of Dr Tranny to see if it improves it. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #435784 Tue Sep 09 2014 2:48pm
Nsp1
Oh dear!
It's 158k miles and I've just got it so not sure if the oils been changed.
Just don't fancy a big repair bill.
How much is a torque converter?
Post #435787 Tue Sep 09 2014 3:03pm
Bodsy
Site Sponsor
About £1,000 fitted at an indi.... Bodsys Brake Bible
See it HERE
Post #435826 Tue Sep 09 2014 8:42pm
Nsp1
Not good.
But thank you.
I'm with the AA and have this parts and labour cover. I'll have to check and see if it's covered.
Fingers crossed!
Post #435845 Wed Sep 10 2014 3:54am
drdelrrs
If you've just bought it, i.e. less than 3 months, you'd have come-back on the dealer/seller.
Post #435850 Wed Sep 10 2014 7:56am
Could also be worth resetting the autobox memory. I believe it 'learns' your driving style, maybe the previous owner was not that sure footed. Worth a try as it's free.
From another thread wrote:
Turn the ignition switch to 2 so that the electrics are on but the engine is not started
Press the brake pedal firmly for 40 seconds
Turn the ignition off and start the engine.
The system should reset itself and adapt itself to your driving style.
 ON THE WAY: BMW F21 M140i
Post #435853 Wed Sep 10 2014 8:53am
Nsp1
I've tried the re-set. Will see how that goes.
It was quite a good deal anyway so wouldn't expect much from the seller. I'm still waiting for him to send the spare key.
Post #435903 Wed Sep 10 2014 4:58pm
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi there. Did the reset work mate. Whistle
Post #577185 Sat Mar 16 2019 6:51pm
