![]() | Home > Maintenance & Modifications > JLR dignostics.... compare to IID |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
Has anyone access to or knowledge of such?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4421 ![]() ![]() ![]() |
Programming subscriptions are required for any form of programming
And it won't cover up to 2018MY, will only do upto 16MY, as anything afterwards reqs Pathfinder |
I has SSD and found it a right pain then bought an IDD so much easier and safer to use.You will not end up with a 2.5 tonne paper weight as you may with SDD |
I have both, IID is very handy. SDD is good for everything else. I paid £50 for SDD with a log in but today it hasn’t worked, the log in screen has changed in the last update. I’ve emailed the seller for an updated password. 2019 5.0 SC SVA (Current)
Seller true to his word has sorted it all out and SDD is working again. 2019 5.0 SC SVA (Current)
