Home > Technical > scraping noise coming from new brakes
Brit Plumber
Just thinking about it again and perhaps the garage who did the work damaged a brake pipe causing a restriction. Check if both discs get hot or just one....or all 4. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577018 Thu Mar 14 2019 6:07pm
f11rfn
Thanks for reply guys a specialist had a look at it he thinks its the wheel bearing on the passanger sidem they will do a proper check on tueday so fingers crossed il get it sorted
Post #577226 Sun Mar 17 2019 1:44pm
