Home > Technical > Can’t play music from iPhone to car.
Demaske1
United Kingdom 2009 Range Rover Sport TDV8 HSE Arctic Frost
My 2009 Sport tdv8 will connect to my iPhone via Bluetooth but it won’t play the music from my phone. I have tried the usb connection under the Centre armrest and plugged that into the phone. The phone will charge but says on the car screen device not found. As for the iPod connection it’s out of dat but I do have a lead to fit it but the other end won’t fit the phone and there does not appear to be a connection to fit it. Everything but in fact. How do I get my phone to play music into car. Can use the aux socket behind centre console as no other socket on phone . Big Cry
Post #570519 Wed Dec 05 2018 8:40pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
The BT connection only works for the telephone, not the music for which you need to use the cable.
What size is the memory of your iPhone? My facelift 2010 MY RRS will load a 64GB Sandisk Cruzer Fit in the USB port, but not a 256GB iPhone by cable so that may be your problem.
Post #576987 Thu Mar 14 2019 10:15am
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
i get the message
"Android File Transfer or Samsung Smart Switch must be installed on Mac OS X Devices"
related
so there is no possibility to stream music from your phone to the car audio?
when i try the phone recognizes it is connected to car and mutes it own volume expecting the stream is playing on the car...
but nothing from the car audio. 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #577000 Thu Mar 14 2019 12:41pm
Goffy
Sorry I can't help you there, I know nothing about iPhones. Good luck!
Post #577017 Thu Mar 14 2019 5:56pm
Godders
I had the same problem with mine 2010 my with the original lead provided. What I have done is purchased a iPod series 4 I think ( this was the one available in 2010.) The problem is that any iPod or iPhone that was made after 2010 has a different power with the electrics and that is why your 2010 lead can't read anything. The older model also has the correct apature for your lead to fit into. You can pick these old iPods up for about £25 / £30. The other way is to buy the adaptor that are mentioned many times on here to connect your iPhone by way of bluetooth but I think they are about £100. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #577034 Thu Mar 14 2019 8:40pm
