Home > General (L494) > Gearbox Software Update on L494 |
Yes, in 2016 at its first service my SDv6 HSE Dynamic had a software upgrade done and it stopped that dying feeling the car had when trying to pull out of junctions and merge into roundabouts. It was so good I hardly needed to use Sport mode again during my ownership of the car. And yes the car was kept in overnight. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Mar 11 2019 6:31pm |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 |
Thanks Tim - very helpful as always.
Tue Mar 12 2019 11:45am |
It was done as part of the service updating Of software upgrades. It was also a gearbox ECU update so shouldn’t have any effect on the engine management ECU as far as I’m aware, but it was a long time ago and I ditched all the service records in December......... so cannot even go back to those to look. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Mar 12 2019 12:01pm |
Thanks again Tim - I’m booked in on Friday. Said it will be one hour’s labour. Interestingly he said that, as it’s a “learning gearbox”, if you bought the car from someone who drove very differently to you, it might be badly matched as it has “learnt” from this other owner. He was confident an update will make a big difference. Finally he confirmed it is gearbox ECU only and doesn’t touch the engine ECU. |
Tue Mar 12 2019 7:00pm |
My car had less than 20 miles on the odo when it was handed over in London, I was the first and only owner although I took a car that was built two days after I said I would take it, it was meant to be a car for a director at the dealership..... so it had jazzy bits I didn’t want like 22” wheels (which turned out to be ok even off road) but was missing things like a heated steering wheel that I consider more of an essential for a car that lived outside (it wasn’t even an option on the mini, but that does have extremely efficient electrically poweded park heating!). Having said that you can wipe the gearbox memory with a service when they disconnect the battery....... so I suppose you could try that! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Mar 12 2019 9:44pm |
GregP Member Since: 21 Jul 2017 Location: Gosford Posts: 52 |
Hi Punkawallah,
Wed Mar 13 2019 12:04am |
Hi Greg - I will ask on Friday and let you know after the weekend.
Wed Mar 13 2019 9:29am |
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 |
+ 1
Wed Mar 13 2019 9:50am |
Your 2016MY should have had that update added on the production line as it was released in early 2016 unless your car is a late 2015 build 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Mar 13 2019 11:46am |
Hi Tim - its a late 2015 build sadly. MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Wed Mar 13 2019 12:57pm |
Ive just emailed the dealer im picking mine up from on fri & asked them to do the gearbox update if they already haven't as the are servicing it & I noticed they mot'd it yesterday. Andy.
Wed Mar 13 2019 2:47pm |
harisson Member Since: 28 Jun 2018 Location: CH Posts: 184 |
Does someone have a release number of this SW? is it possible to check it via the hidden menu of the entertainment system?
Thu Mar 14 2019 10:50am |
HXM Member Since: 24 Jun 2018 Location: Up North Posts: 81 |
Interested to know the outcome as well. The roundabout thing is highly annoying.. MY15.5 HSE - SDV6 - Santorini Black |
Sun Mar 17 2019 6:51pm |
Ok, had the update done.
Mon Mar 18 2019 10:50am |
