Home > Technical > AFS head light problem |
Ginge Member Since: 28 Dec 2018 Location: Swindon Posts: 26 |
I have the same issue and just want to know if I can disconnect the warning light on the dash as I don't need afs so I don't care that the upgraded lights don't have it! Hoping I can just unplug something so I don't have to see that flashing light |
Sun Mar 10 2019 9:27am |
Alz Member Since: 03 Mar 2019 Location: Wolverhampton Posts: 4 |
I have been in phone to the firm the makes the lights and the adaptive lights will not work unless the car is from 2010 you can’t turn the adaptive warning light off as the car is picking up a fault I don’t no why there selling the lights as 2005 /2010 upgrade if they don’t even work correctly as none of the ads say the adaptive lights will not work also I have adaptive lights with cornering light and the cornering lights have burned out useing the h8 35
Sun Mar 10 2019 9:45am |
There is a you tube video that says using the Gap IID tool you can turn the afs to 'not fitted' and then the warning light doesn't appear
Sun Mar 10 2019 10:29am |
Yes you can on the older Range Rover but not on the Range Rover sport I have Range Rover diagnostic machine and that video isn’t the Range Rover sport |
Sun Mar 10 2019 1:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
they are similar electronics though.
Sun Mar 10 2019 2:36pm |
In my experience with LR diagnostics, if the CCF doesn’t show it fitted, it won’t BIT it through the CAN bus and therefore won’t find errors. 2019 5.0 SC SVA (Current)
Sun Mar 10 2019 8:01pm |
My rrs has the autobiography kit fitted s on originaly (I believe) it had afs but with the new lights it doesn't have this so the computer is confused and throwing up this fault so after watching the you tube video I wondered if it would work on mine and turn off afs it's a 2008 |
Mon Mar 11 2019 6:47am |
It’s got to be worth a go trying to turn it off. I’m pretty sure it would work.
Mon Mar 11 2019 11:54am |
I have ordered the Gap IID tool and can't wait now to see if I can sort 2 of my problems by using it 🤞🤞 |
Mon Mar 11 2019 10:21pm |
Afs update
Fri Mar 15 2019 6:35pm |
