![]() | Home > Technical > Black smoke on acceleration |
RJM16 Member Since: 11 Nov 2016 Location: Worcestershire Posts: 29 ![]() ![]() ![]() |
My 2012 does the same and there is a Land Rover Technical Bulletin that suggest a mod to the crankcase breather on certain vehicles with VIN’s between AA212145-DA814376 years 2010 - 2012.
Black smoke is a boost leak, or too much fuel
pre7amble Member Since: 01 May 2018 Location: Norfolk Posts: 13 ![]() ![]() ![]() |
Hi, thanks for the prompt replies, my Vin falls outside of the suggested group but I will certainly look at the bulletin. I have checked the hose it looks OK. Would a split hose not cause black smoke every time you accelerate mine has only done it once. I was curious about the readings as a learning process in understanding my car more.
MrGimper Member Since: 05 Jun 2016 Location: Andover Posts: 57 ![]() ![]() ![]() |
I had black smoke under acceleration and it was that hose/downpipe that was split. Check underneath the hose near the top as mine had split there and wasn't obviously visible. |
johnrambo Member Since: 30 Jan 2019 Location: scotland Posts: 27 ![]() ![]() ![]() |
fuel dump
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 ![]() ![]() ![]() |
Had the same ok normal driving but if I booted it got clouds of black smoke. Turn out the intercooler had split |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 ![]() ![]() ![]() |
I was suffering this on my 2.7v6, fitted an EGR blanking kit and no smoke, for £20ish it was a cheap and relatively quick and easy fix.
