![]() | Home > Technical > Locking rear diff - how do I know whether one is fitted? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
The original RRS (and the facelifted one) had complete looms fitted. The loom had every wire and connector in place even if the item wasn't fitted at the end of the wire. The only thing one needs in order to fit the rear locking diff to one of these models, is the diff itself, some wiring to connect diff to loom, new rear driveshafts (unless you are doing it to the TDV8 which already has the uprated shafts as standard) and changes to the CCF. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
It can’t be every option as I don’t have any wiring for (or didn’t) for surround cameras, family entertainment system etc. Etc. 2019 5.0 SC SVA (Current)
They aren't part of the main loom though, they're a separate system. 2012 SDV6 - it's missing a couple of cylinders
