![]() | Home > Maintenance & Modifications > Suspension - No access/ Extended mode |
The suspension compressor contains an air dryer element. When sucking fresh air in to pressurise the system, the air travels through the compressor, through the air dryer and into the suspension system. When the system is being depressurised to lower the vehicle, the air travels back through the dryer before being exhausted to atmosphere. This is to expel any built up moisture in the dryer.
GSJ Member Since: 08 Dec 2016 Location: Cardiff Posts: 36 ![]() ![]() ![]() |
Hi there,
Thanks - it's a pity it's off the road waiting for a new engine |
D|o you have any red blocks above the wheels on the screen when its lowered /extended |
New engine?! Oh no!! What happened? I’m just looking around for a garage to do my cam belt - aux belt service. I’m a bit worried about the engine too, and hearing your news makes me verrrrry nervous
Hi there,
Had this last month after pressure washing. I drove to a mates house, left the car for 5 mins and when I started again, it had cleared. I think it was a height sensor but didn’t have any red bars on the 4x4 screen 2019 5.0 SC SVA (Current)
That's really interesting!
Yes, I suspect a spun main bearing unfortunately ![]() Concerning the belts, they aren't too much trouble to do yourself if you are a DIYer. I did mine back in October. Concerning the height sensor, they are a little plastic arm. Like this... ![]() MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Oh man, that noise is sickening.
No problem at all mate. I'm from Newport originally and if I was still around that neck of the woods I would have offered to do the belts for you.
True gent. Thank you
Did you get this sorted after Gareth?
I cleaned out and installed new seals on the front valve block of mine today.
