![]() | Home > Maintenance & Modifications > Alive agent or alive headquarters? |
Isnβt Bodsy based down south somewhere.? Andy.
Believe Rover Tune in Reading are an Alive agent |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
Any Alive agents further SE??
Alive website has the full list of agents.
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 213 ![]() ![]() ![]() |
Appears there is one in Broadstairs A1 Motorist Centre Ltd Unit 2, Patricia Way, Pysons Road Industrial Estate, BROADSTAIRS, CT10 2LF |
Thank you |
I thought agents still had to remove and send away ECU regardless or can it be done via OBD now? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
If that's the case then not much point using an agent as would need the car back the same day.
Watching vids of other places that do this remapping,
Some agents have the kit to read/write the ECU on the bench, and turn the job round same day ![]() https://www.facebook.com/700199706667330/posts/1353738851313409/ Although this is on a Defender, the process much the same ![]() |
I'm thinking I might just take it to Alive headquarters and have it done as I like the fact you can have it put on the Dyno to confirm everything is as it should be and also you can see the improvements on paper 2017 SVR. SVO Scafell grey Ebony interior 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone |
keep us informed what you do and how the car drives once done,
The biggest issue for me is the pulling out of junctions as when you first put your foot down it just creeps forward in to oncoming traffic so because not much has happened you push down more on the Throttle pedal and then when it decides to wake up you come out the junction like a lunatic.
It helps to select Sport mode before a busy round about, but in my experience the map does sort it out |
