Home > In Car Electronics > Landrover diagnostic tool/ reader
Iggy
United Kingdom 2011 Range Rover Sport SDV6 HSE Santorini Black
Hi all I am thinking I need to purchase a diagnostic tool as I have a collection of these vehicles 2011 Range Rover sport/2008discovery3/2004Range Rover vogue/ all with there ongoing issues. Can anyone recommend an affordable tool.
Any ideas would be appreciated
Post #576209 Sat Mar 02 2019 5:51pm
skid1963
Can't go wrong with an IID tool.....not sure i would call it affordable though Very Happy
Post #576212 Sat Mar 02 2019 6:22pm
Disco_Mikey
£400 is less than the average repair on a Sport Laughing
Post #576220 Sat Mar 02 2019 7:42pm
Brit Plumber
I’ve got the IID BT from gap and it’s handy for the glove box but I also have the VCM2 and Use JLRs on line SDD which is more complicated and takes a while to set up but as it’s what JLR use it covers nearly everything and cost £140 for the VCM2 and £45 for the genuine online version of SDD (it updates pretty much all the time which can get tedious). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #576242 Sat Mar 02 2019 11:58pm
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Hi mate.
Have you got links of where you bought the devices from? ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #590034 Thu Nov 07 2019 5:50pm
Brit Plumber
The IID came from Duckworths and VCM came from
http://www.cartool.co.uk/wholesale/new-rel...-wifi.html
There are some VCM2 out there appear cheaper but are actually DaVinas in a VCM2 case (ebays full of them). These can be blue or red and are crap. The site above shows you the board which is correct, the DaVina board is much smaller and with less connections.
Be aware you need to use it JLR SDD as it’s not standalone like the IID tool. 2019 5.0 SC SVA (Current)
Post #590040 Thu Nov 07 2019 7:32pm
McFarTech
Thanks mate. Is the SDD a cable?
Just getting my head around what I need. I come from Audi land where it’s just VCDS
Craig ===========================================
Post #590041 Thu Nov 07 2019 7:36pm
aaronjb
The SDD is the software - which appears to be a minefield as there are lots of 'cracked' or hookey copies being sold online/ebay/etc that won't update or come with support..
Chris - where did you get SDD from? Direct from JLR or is there an authorised reseller? I'm partial to a bit of laptop-based diagnostics too (I'm used to the BMW gear) Thumbs Up 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590085 Fri Nov 08 2019 10:24am
Brit Plumber
It was a JLR download but it can be a PITA! It updates nearly every day and if you don’t turn your computer on for a week it has lots to update involving turning off before moving to the next update. 2019 5.0 SC SVA (Current)
Post #590092 Fri Nov 08 2019 11:17am
aaronjb
My diagnostic laptop (still running XP!) doesn't get turned on much, so I'm used to that.. might actually have to invest in a slightly newer laptop, given XP is now (long) out of support - I don't like connecting it to the Interwebs, just in case.
A little googling just got me to download links on Topix - I assume then you just have to register for an account and pay somehow? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590094 Fri Nov 08 2019 11:20am
knwatkins
Here is the JLR download link for SDD....
http://diagnosticdelivery.jlrext.com/idscentral
Hope this helps Kev
Post #590109 Fri Nov 08 2019 4:09pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I have a Blackbox Solutions Faulmate MSV-2 Extreme. It costs around 1,100 Euro.
Is there any better product out there?
Post #590485 Sat Nov 16 2019 2:13pm
Dave B
Just bought an IID BT from Duckworth Land Rover for £429.99, with the VAT off it works out @ £358.32 which is the cheapest there is for this model, and a bargain.
If there is a downside for you, it will be the full monty can only be done on 2 vehicles, however I think, and I may need correcting, you will be able to diagnose on more than 2, just not configure.
Didn't go direct, but via a well known auction site.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #590487 Sat Nov 16 2019 2:28pm
McFarTech
Looking to pull the pin on this.
So I need the VCM2 which is currently £126
There is a link above for the JLR software and outside of that just need to purchase a key? Am I correct?
Also does the software just let you check for faults or does it let you make changes to the car? Enable or disable stuff?
Post #593069 Thu Jan 09 2020 7:59pm
McFarTech
Also. Thoughts on this or stay away?
https://www.jlridssddmongoose.com/home/jag...v138-v131/ ===========================================
Post #593070 Thu Jan 09 2020 8:02pm
