Home > Technical > Drivers Seat memory module question
Ziguk
England 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi
Have a problem with front drivers seat and mirrors not working was getting a rapid relay clicking sound whether ignotion was on or off, then nothing.
Checked all fuses all fine, checked power was getting to memory module it is
I think memory module probably has issue I have found a brand new replacement does anyone know if this would work
Physically the box is same, with same sockets
The one I have found is slightly more modern
Current module YWC000784 Jca 320884AA hardware version V5.0 software version v9.1 Date 0505
new Module YWC000785 Jca 320884-3 hardware version V5.0 software version v9.2 Date 0512
I suspect this is an updated version which in theory may actually be better than the original one fitted.
If this has to be coded to car what is the software normally used for this?
Thanks
Post #575861 Mon Feb 25 2019 12:08pm
Xrover
United States 2008 Range Rover Sport 4.4 V8 HSE Zermatt Silver
I had the same clicking noise problem you mentioned. I disconnected all the connectors on the module and let it sit for 30 minutes. Reconnected them back and haven’t had a problem since. You might want to give that a try before buying another module 2006 LR3 HSE
2008 RRS HSE
Post #576049 Thu Feb 28 2019 12:20am
Ziguk
Thanks did try that took module out for a few hours plugged back in now I get nothing at all
Post #576089 Thu Feb 28 2019 10:13pm
geoffsnook
Plug it in and see it will either work or not would not have thought it would need coding but i stand to be corrected i thought you only needed to tell the car it has powered seats Thumbs Up
Post #576142 Fri Mar 01 2019 7:16pm
Xrover
If your power seats are not working after you re plugged the module back in then the module is probably dead. I’d replace it with the same Part # unless LR has a superceded part #. There shouldn’t be any programming needed for a new module. 2006 LR3 HSE
2008 RRS HSE
Post #576143 Fri Mar 01 2019 7:27pm
