Home > General > Tachometer Needle Light Flickering
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
The tachometer needle light on my 2010 TDV8 has just started to flicker. All other lights on the instrument display are working fine. Is it a simple case of of pulling out the instrument cluster and checking a bulb or is it something more complex?
Post #576132 Fri Mar 01 2019 4:41pm
Disco_Mikey
The needle is lit by an LED. It is this that fails, and eventually, will stop illuminating altogether
No idea if they can be repaired, I've only heard of a new IPC being fitted
Post #576138 Fri Mar 01 2019 5:33pm
gogsy1956
Mines been doing that for a while now,, i've tended to forget about it. It's quite a common fault but their are places that repair and even customise them, normally around the £150 mark but unless you live local you would have to send them the cluster
Do a search on Google for instrument cluster repair and you will find a few options. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #576210 Sat Mar 02 2019 4:57pm
