Home > General > New toy.... what should i look for
findlayscott@yahoo.co.uk
Hello. Very Happy
I am off to test drive and buy (hopefully) a supercharged beastie today.
LB55 VZG
140000 MILES
i know to check everything actually works
rise and fall of the suspension
What else should I be looking out for?
Findlay
Post #575768 Sun Feb 24 2019 9:13am
any doubts with the gearbox, I would walk away
Post #575769 Sun Feb 24 2019 9:26am
Nicely done... thank you
Post #575770 Sun Feb 24 2019 9:39am
Anything else from anyone else?
I'm a bit nervous and excited at the same time!
Post #575772 Sun Feb 24 2019 9:52am
Cymruambyth
Wales
No squeal on the EPB. Steve.
Post #575774 Sun Feb 24 2019 10:04am
geoffsnook
If the aux pump for the supercharger has not been changed check to see if it falls within the range as quite a few came out of the factory with them wired the wrong way which when driven hard can make them go into limp mode you can search on here about it Thumbs Up
Post #575776 Sun Feb 24 2019 10:15am
these do 13 MPG on fuel
check the fluid level container on the air box (ACE) is on a mark, and doesn't drop after your test drive. (it may go up when hot) this can be expensive to repair if dropping/leaking
On cold startup, listen for any chain rattle from front of engine, and knock off ~£800 if loud/bad
Post #575778 Sun Feb 24 2019 10:18am
Flexzor
Belgium 2009 Range Rover Sport TDV6 HSE Java Black
Also listen for a rattle on the snout of the supercharger.
The plastic clutch can be worn and this will cause rattle in idle.
Post #575780 Sun Feb 24 2019 10:29am
This is gold dust. thank you all..... wish me luck for 14.00!
Post #575784 Sun Feb 24 2019 11:46am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I'd suggest a generous bank manager Smile
Post #575829 Sun Feb 24 2019 8:16pm
Thanks again for feedback.... here is what i found today..... Auto trader dealer....mentioed nothing of any of this in the add!!
ignition on....
1) hdc fault system
2) Parking brake fault..auto release not functional
3)Special programmes off
4)Transmition fault traction reduced
5)another park brake fault
6)suspension fault....unable to raise or lower suspension
7) Category N write off
Cool front bumper 'lashed on'
9) Paint flaking off the back door slam pannel
10) drips of paint where the front wing had been sprayed
11) No service history
12) bloke selling it isnt on the logbook!!(wtaf)
13) sun visor smashed
14)....and this really spoilt it for me.... washer liquid low.....
Post #575842 Sun Feb 24 2019 11:06pm
Rolling with laughter
Post #575843 Sun Feb 24 2019 11:07pm
Why not have a look at this one?
http://www.rrsport.co.uk/forum/topic53371.html
Post #575847 Sun Feb 24 2019 11:25pm
Dealers don’t put the log book in their name.
A low battery can cause hdc faukt
Post #575848 Sun Feb 24 2019 11:50pm
Thanks for the HDC... i was going to do some homework on that
Post #575854 Mon Feb 25 2019 8:13am
