Home > Technical > New here - non starter fuel pressure problem P0191-23 Tdv6
annette
Sorry to bother you, I asked on rangerovers net but was told off because it is a diesel
This is a 2009 TDV6 from Panamá.
it came in with a sticky injector, after it failed various times on the road, so I went to pick it up
all 6 were serviced, one had to be replaced.
I have done the 20x bleeding.
there is diesel coming at the ramp.
But the engine will crank and crank and crank and won't start. Regarding alarm, there is a horn relay error , which I just learned came from a damaged horn. Soemhow I don't think this would immobilise the engine or does it?
The only engine related error I get is P0191-23, my IIDtool zaps it but it comes back after every attempt to start.
IID Tools says the fuel rail pressure signal stays too low.
I had only once another error P0001-13 which IID tool lists as unknown.
after bleeding 20 minutes (ignition on off etc 30secs each time)there seemed to be more pressure at the bleed valve.
We could not see any air.
Fuel pressure in my Iidtool is ZERO. VCV and PCV work
Had the tank down, could not find any residue wort talking about and pump seems to works fine, after all .5 bar is next to nothing.
The fuel filter was changed by the owner only 3 weeks ago, unfortunately, it is Britpart
thank you in advance for any intelligent ideas
Post #575662 Thu Feb 21 2019 7:04pm
SRE
Spain
Look for Robbie's Guide To The Low Pressure Fuel System on the Disco 3/4 Forum In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #575694 Fri Feb 22 2019 2:23pm
SRE
Spain
Found it, save you looking
https://www.disco3.co.uk/forum/robbies-gui...30062.html In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #575695 Fri Feb 22 2019 2:24pm
annette
thank you
thank you,
we have done all that. But the problem is on the HP side.
I get 0 bar on my pressure sensor
would appreciate if somebody could tell me resistance it should have between pins 1 and 3 or 1 and 2
Post #575699 Fri Feb 22 2019 6:02pm
SRE
Spain
Annette
You need to join the Disco 3 & 4 Forums, those guys are more into the technical side Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #575725 Sat Feb 23 2019 9:59am
annette
thank you, alas they aren't in that case.
The only good answer so far was on rangerovers.net. But I will stay, somebody might need me one day
Post #575895 Mon Feb 25 2019 8:31pm
