![]() | Home > Faults & Fixes > HDC, ATPC, E-Diff, not available, ABS fault on L494..Help!! |
Heuerman Member Since: 23 Aug 2011 Location: Nottinghamshire Posts: 62 ![]() ![]() ![]() |
Low battery voltage? '10 Range Rover Sport TDV8
Badgerfife Member Since: 02 Jan 2017 Location: Fife Posts: 26 ![]() |
Thanks. Just checked it. All ok. Popped in to have codes checked.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Brake light bulb. 2012 SDV6 - it's missing a couple of cylinders
Update.
nick09@live.co.uk Member Since: 08 Jul 2020 Location: East Yorkshire Posts: 5 ![]() ![]() |
Hi I’ve got exactly same problem how did you fix ? Thanks |
Brian181 Member Since: 10 Dec 2024 Location: Aberdeen Posts: 4 ![]() ![]() ![]() |
Hi, can you advise me which abs sensor wire & earth point you had the problem with?
