Home > General > rear wheel bearing removal
PC76
Hi all,
i asked this question but burried it in my other post under maintenance, need to get the job sorted before going away this weekend, so a quick answer would be greatly appreciated.
What bearing removal tools are needed to sort the rear wheel bearings? will the below work?
https://www.ebay.co.uk/itm/27pc-Press-and-...:rk:8:pf:0
Thanks
Post #575026 Mon Feb 11 2019 6:28pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
That set would be fine for installing the bearing but you might have a job getting the old one out . You would normally remove the hub and use a press .
Post #575031 Mon Feb 11 2019 7:15pm
PC76
Thanks Rich,
i'm hoping that the studs are up to taking abuse from my Dewalt impact wrench... Shocked
Post #575034 Mon Feb 11 2019 7:48pm
rich_sargie
Make sure you cover the threads with cv joint grease . And also make sure the bearings on the nuts have some lubrication.
Do not use your impact gun as this will damage the threads juts use a spanner and socket and ratchet.
Post #575051 Mon Feb 11 2019 9:42pm
