Home > Maintenance & Modifications > Rear End wobble & whine
PC76
Evening all,
Well it looks like i need to replace the LHS rear brake disc/pads & calliper as every time i press the brake i get the wobble from the back end. tracked it down to the LHS. i am also getting what i would term a bearing noise although only slightly but enough to any me..
For those that have replaced the rear bearing, can you please confirm what tools you used as i don't currently have a hub/bearing puller and would like some advice on which one to buy.
Also a company called simply bearings which is reasonably local to me sell the bearings..has anyone ever used them before?
https://simplybearings.co.uk/shop/p754583/..._info.html
TIA
Peter
Post #574997 Sun Feb 10 2019 11:58pm
