![]() | Home > Off Roading & Green Laning > Blimey, these cars are capable!! |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Having a nice day...
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Quick wipe with a old towel and that'll be good as new! |
It came back scratched to |
Mine looked like that a few weeks ago when I was out feeding pheasants. Had to go across a wet field to get to some feeders. Absolutely caked in mud and the tyres looked like muddy doughnuts. It then rained overnight which got rid of most of the mud! |
The dent came from sliding into a tree (it jumped out of nowhere, honest!) It isn't creased, so might be retrievable.
It is called super-extended mode and you can force the car into it but you would have to cross my palm with silver to get the secret out of me! |
What ground clearance sensor is that then Tim, other than the four ride height sensors?
Of you could look at the Land Rover Passion suspension ECU that i use |
Diversurfer Member Since: 24 Mar 2018 Location: Bragança Posts: 19 ![]() ![]() ![]() |
I there, would the "Foot on the brake pedal and hold the raise button for a few seconds and you can then get super extended mode" work if you don't bottom out first. I think the D3/4 can do this at anytime, would the RRS do the same? Cheers |
I have the DR pack on mine. do you mind sharing! ![]() ![]() ![]() ![]() |
No, the extended mode is not selectable without first grounding. Similarly, super extended mode (foot on brake etc) only becomes available once extended mode is active. This is the same as the Disco. You can buy kit that allows full height selection, and some forum members have done just that. ![]() 2008 TDV8 - it was a labour of love and is much missed |
People following me when I have been in Off-Road + 50mm (via the Easylift and the same height as extended mode) have commented that the [rear] wheels have started to 'tuck in' quite noticeably. |
Yes, the suspension geometry makes the camber change a lot as ride height changes. 2012 SDV6 - it's missing a couple of cylinders
A good justification for not changing ride-height when the car isn't moving and is on tarmac. If I am playing with the Easylift, I make sure the car is moving - even if it means forwards/reverse over a few metres. |
