![]() | Home > In Car Electronics > What android unit have you fitted? |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
M9G UK, have a look here. I fitted this last year and am still playing around with the final set up. Currently using Head Unit Reloaded to run Android Auto over WiFi and am looking to invest in a inCarTec MOST converter to be able to use the existing FOC amplifier to cut down on the cables running through the Sport.
M9G UK Member Since: 02 Feb 2019 Location: Somerset Posts: 160 ![]() ![]() |
Cool thanks will have a good read of it all later, I will probably go down the easy route due to time, work and family. Will a standard double din unit just fit in then? I wasnt sure if the original stereo was a standard double din size and if there would be any issues with cables and canbus
