Home > In Car Electronics > Wheres my aux input gone?
M9G UK
Thank you everyone for your help, really appreciate it Thumbs Up
Post #574901 Sat Feb 09 2019 7:58pm
M9G UK
Ok so it arrived today and I plugged cables into it, cigarette lighter socket works but im getting nothing through the speakers when I plug an ipod into the aux socket and change the stereo to AUX Sad
Anyone got any ideas please?
Post #575104 Tue Feb 12 2019 4:38pm
1. Make sure the ipod volumn is on MAX
2. Make sure the headunit volume is high.
If that doesn't work, there is a connector in the front footwell (left) where the red and blue cables join.
Post #575107 Tue Feb 12 2019 5:42pm
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Bizarrely neither does mine? But it does have a factory fitted Ipod connector in between the front cup holders, and that works off the AUX button Question Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #575108 Tue Feb 12 2019 5:59pm
M9G UK
Ok thanks, yeah had volume right up, will check wires tomorrow when light
Cheers Thumbs Up
Post #575109 Tue Feb 12 2019 6:05pm
Scrumpy
I had similar issues with volume and aux input but mine worked although very quiet.
I found the perfect fix was to buy an iPod (30 pin?) to 3.5mm jack cable cured this.
Don't know if it helps but hope it does! 2016 RRS SVR Estoril Blue
Post #575116 Tue Feb 12 2019 8:10pm
M9G UK
ok cool thanks Thumbs Up Thumbs Up Thumbs Up
Post #575126 Tue Feb 12 2019 9:33pm
M9G UK
Hi Andy, where is the connector please? do I have to remove the panel under the glovebox?
Post #575171 Wed Feb 13 2019 4:52pm
No
Did you plug in the small connector with the red and blue wires into the new panel ?
To get to the footwell connector, you have to unscrew the bonnet handle with a torx bit
and then remove the plastic panel
Post #575173 Wed Feb 13 2019 5:48pm
M9G UK
yes all plugged in, have tried different 3.5mm cables and tried my phone aswell as an ipod and whacked the volumes up to full
I thought I would have to remove the panel, thanks for confirming
Appreciate your help Thumbs Up Thumbs Up Thumbs Up
Post #575174 Wed Feb 13 2019 6:02pm
M9G UK
Andy K wrote:
No
Hi Andy, so I have taken the panel off below the glovebox but im not seeing any connector, any idea roughly where I should be looking up under there? wouldn't the wires just run through the centre consol and then up behind the stereo?
Cheers 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Xtrons Android head unit
Smile
Post #575782 Sun Feb 24 2019 11:15am
Pm me your email address and I will send u a photo
Post #575799 Sun Feb 24 2019 2:03pm
Phone won’t let me send a pic Sad
Remove the bonnet pull handle
Remove the trim behind it.
You should see 3 connectors.
It’s the middle one
Has red and blue wires and some seat wires too
Post #575801 Sun Feb 24 2019 2:16pm
Pic sent.
OP found the wires stopped at the footwell A pillar
Post #575802 Sun Feb 24 2019 2:21pm
M9G UK
Received thanks Thumbs Up Thumbs Up Thumbs Up 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #575803 Sun Feb 24 2019 3:06pm
