Home > General > Anyone used the TDI-Tuning box ?
Smarttech
Would like to have my car remapped but due to warranty I'm not keen on the idea of having my Ecu removed and opened up.
I've heard stories of tuning boxes just fooling the Ecu in to thinking its running standard fuel and boost but then upping these to get the power but not changing the important details the Ecu need to run the engine safety.
Anyone know if this is true and are the TDI-Tuning boxes the same or a good version of these type of power upgrade boxes ? 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #574476 Mon Feb 04 2019 9:01am
Brit Plumber
I wouldn’t bother, it’s just a trick so will end up being a waste of money. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #574477 Mon Feb 04 2019 9:18am
geoffsnook
They do work buy they are not ideal they do fool the ecu but some of them are absolute Censored so be careful running a box on my gt Renault as its only a cheapo back and forth work makes a difference to power but fuel consumption is a few miles per gallon worse my Disco3 had one on to but that was not as good every now and again from low revs and full throttle it would go iton limp mode dip of clutch and it would come back to life Thumbs Up
Post #574488 Mon Feb 04 2019 10:16am
Disco_Mikey
They do work, but remove any safety parameters within the ECU. Use them at your own risk...
Post #574501 Mon Feb 04 2019 1:25pm
Smarttech
Sounds like a stay clear job and wait for warranty to run out then. 2017 SVR. SVO Scafell grey Ebony interior
Post #574503 Mon Feb 04 2019 1:32pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I can understand reluctance to have your ecu out and opened. All I can say is that is the process on my SDV6 MY 2012 and Alive did mine 3 years/50k miles ago with no problems at all.
Post #574547 Mon Feb 04 2019 9:47pm
loadshifter
United Kingdom 2009 Range Rover Sport TDV8 HSE Orkney Grey
Had one on mine for a couple of years now no problems kicks out a lot more Bhp and Torque and more miles to the gallon,On the way down to cornwall managed to get 34.1 from a V8
 The careful overtaker avoids the undertaker !
Post #574860 Sat Feb 09 2019 1:15pm
