![]() | Home > Technical > ATC (automatic temperature control) module Help!! |
The arc is the unit in the dash with the buttons on.
Ziguk Member Since: 01 Feb 2019 Location: Wrexham Posts: 19 ![]() ![]() ![]() |
Hi
This is probably what you are looking for, however you would need to verify part number based on Vin No. as per usual with L/R there are numerous choices based on the options you may have fitted to vehicle, although a lot will have superseded to same number. The picture you have posted appears to be for Facelift Variant of the RRS1 2010 on, not a 2005 year vehicle.
Thanks
Those picture are for a 2010 on vehicles, not 2005 as you say you have. I suspect you have the workshop manual for the 2010-2013 vehicles not 2005-2009.
Thanks I thing your right about the manual although judging by the pic of the climate controls looks like same system
Do to heated window switches and seats light up when pressed?
Hi
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Sounds like a stuck air mix flap to the passenger side, likely a motor failure. I think they are a Delphi product, so not all that reliable |
Thanks
there is 1 fuse which only does that one water pump. The fuse is know to fail if the water freezes (it's below 0 ATM).
They all sound common faults to me and I wouldn't blame the "ECU" ATC
Fuse 11 behind glovebox for water pump.
Thanks
