Home > Technical > Suspension fault when cornering range Rover sport 2009 2.7
Loverrs
I have some problems with my range Rover sport I have change the steering angle brand-new plus the compressor but the problem is still there. All the cables and the wiring has been checked there is no issue been found I don’t really know what I really appreciate it if someone had same situation as me.
Does anyone know a good reliable specialist Land Rover range Rover garage
Looks like I’m not alone there is a lot of people with the same problem Landover need to come up with a solution
Post #573906 Sat Jan 26 2019 11:20pm
loadshifter
United Kingdom 2009 Range Rover Sport TDV8 HSE Orkney Grey
Silly question but have you checked the hydraulic fluid in the reservoir The careful overtaker avoids the undertaker !
Post #574189 Thu Jan 31 2019 8:13pm
Loverrs
I have found the problem The problem is with
body control module
Dynamic respond module
Vehicle dynamic module
Post #574261 Fri Feb 01 2019 11:40pm
