Home > Technical > TDV8 mystery smoke from left side of engine
E31Gill
I've had my 58 plate TDV8 for over a year now.
In the time I have owned it, I've had to replace the coolant expansion bottle and the suspension lift pump and the upper two intercooler hoses which had degraded.
On my recent MOT, the inspector advised that I had a oil leak on the left side of the engine and smoke is eminating from the side of the engine but he could not see where it was coming from. The smoke seems to come from about half way down the engine (not the FBH) I can only assume one of three things (1) oil is touching something hot (2)that the lower pipe to the left turbo has split (3) the rocket cover gasket has failed on that side. The smoke starts pretty much straight away even from cold before any gets a change to heat up so I think that the most likely source will be some kind of exhaust leak
Are there any other owners who can shed some light on this problem? Is it common?
Post #573733 Wed Jan 23 2019 8:29pm
Is this "left" when stood in front looking in to the engine bay or when sat in the driver's seat? 2012 SDV6 - it's missing a couple of cylinders
Post #573752 Wed Jan 23 2019 11:25pm
E31Gill
The left side of the car when sat in the RHD drivers seat, i.e UK passenger side of the vehicle....
Post #573937 Sun Jan 27 2019 12:35pm
