Home > General > FBH on 2012 face lift rrs
Chas9
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Hi guys could any one give me any information on how to operate FBH feature on my v6 diesel rrs. Thanks
Post #573188 Wed Jan 16 2019 7:19am
mrluke
1.) Remote Control ( if available )
2.) I think its called timed climate control in the Entertainment system.
Post #573704 Wed Jan 23 2019 2:45pm
Bardley
FBH
Take a read here as it's the same setup with an option on the dash (if enabled).
This can also be enable thro' the Car Confg. File (CCF) by someone wit the suitable tool. Be aware that LR dealers may well tell you it cannot be done.
https://www.disco4.com/forum/webasto-fuel-...-vf96.html 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #573708 Wed Jan 23 2019 3:32pm
Godders
Ive just enabled my 2010my FBH with my Bt iid tool as it had been disabled. When you turn your car on in the cold weather it will automatically come on and you can set it to a time via the menu screen. You ca also buy or set up with a fob. Very easy to enable using the tool, I got the how to off this forum. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #573712 Wed Jan 23 2019 4:49pm
Chas9
Magic guys thanks for help have ordered GAPII D . Diagnostic tool to enable timed climate control features. Many thanks
Post #573755 Thu Jan 24 2019 4:38am
Bardley
The FBH is an automatic unit that will come on IF it's cold and the engine needs help in warming up. This is standard.
An option, at build, is to have the ability to preset a warm up time that also activates the internal fan to pre-warm the car interior ( also clearing windows in frozen conditions...). This is the part that LR charge for, tho' it's merely an electronic switch to have it on...
This option is enhanced with a remote operation, and not necessarily together with 'timed' on the same car.
The 'option' can be activated aftermarket using a tool such as the GAPIIBT unit. Many Disco4 owners have this tool and have done this. The GAPII unit is car (VIN) specific for changing car settings, but will read codes of other LR's. A GAPIIBT PRO tool is able to change the settings, and the guys on the Disco4 site have these and can also supply/fit a unit for you.
The timed activation has to be enabled, as does the 'Radio' operation for a remote control. The remote has a plug in receiver device, and aerial & and a small fob to switch on/off. There is also an aftermarket 'ALTOX' branded unit that will fit in the same location as the LR unit, and this enables a full remote facility via a SIM card. An APP on a SMART phone will control the unit, and has many features that some people quite like.
Read here:-
https://www.disco4.com/forum/webasto-fuel-...1ece4307c8
and here for the ALTOX:-
https://altox.ru/en/products/altox-wbus-5-gps/
The Altox unit is available in UK and there are suppliers/Fit on the forum. Use the first link to search.
If you are competent with a spanner and electrics/gadgets, these are easy fit, but the CCF (car configuration file) in the car will need setting appropriately.
Hope that helps...
Suggest you PM one of the forum suppliers, and get a quote. 2011 MY D4 HSE
Post #573758 Thu Jan 24 2019 7:46am
