Home > General > I phone 8 to RRS MY2010.
DeeWee
England 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Any one got any idea of how or if an iphone 8 could be connected to play music through the stereo in my 2010 HSE RRS? It certainly I doesn't appear to be simple. 🤔
Post #572846 Fri Jan 11 2019 4:55pm
Brit Plumber
I think you can get a device called a parrot or something like that. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572849 Fri Jan 11 2019 5:28pm
Bustanut
You need one of these
They don’t come cheap, I paid about £80 but I tried everything else’s and it didn’t work. It plugs in under the armrest into your existing lead and let you use all the controls etc. On the steering wheel whilst streaming music from your phone.
Post #572863 Fri Jan 11 2019 6:56pm
ilard
You just need the Land Rover iPod cable with an Apple Lightning to 30 pin adapter. You can then select music either via the centre touchscreen or on the iPhone itself. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #572867 Fri Jan 11 2019 8:21pm
ilard
This is Bustanut’s suggestion (version with LR cable if you do not have one):
https://www.amazon.co.uk/dp/B01N9EQ5PW/
It’s very well reviewed... an interesting upgrade idea for me... L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #572869 Fri Jan 11 2019 8:23pm
Godders
I have a 2010 and had the same problems with new apple phones...i.e. anything after 2011 apparently because of the different voltages or something between the older phones for which this was designed and newer phones. Even with a legit LR iPod cable it wouldn't work. I then purchased and old iPod off eBay pre 2010 and it works fine now with the correct iPod connection cable. You can use the jack plug situated in the rear of the centre console and plug that into your new phone but you cannot control song lists etc via touchscreen or steering wheel controls. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #572899 Fri Jan 11 2019 10:55pm
ilard
Mine is 2011MY but I doubt it’s different ICE to 2010MY? I used to use a 2006 iPod, and then used iPhone 5, 5s, 6, 8 Plus and XS Max... all of which have worked fine. Sometimes the iPhone 5 can be a bit buggy throwing device errors. iPhone 8 Plus and XS Max have been rock solid.
My cable is LR original, supplied as part of the factory order (£30!). L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #572901 Fri Jan 11 2019 11:20pm
PC76
I have just fitted a Parrot system, it works well but can be a little quiet on the phone calls, you will need an adaptor harness which you can get from Incartec
Post #572903 Sat Jan 12 2019 12:36am
