![]() | Home > Technical > DPF Regeneration and Oil Dilution |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
Steve's question is an interesting one. I have had a dpf full message 3 times in 3.5 years/50k miles and each time a 30 min drive has cleared it but otherwise no known problems nor have I been aware of any regeneration cycles occurring (such as on motorway trips etc). |
In 4 years ive never had a message telling me its full or performing a regeneration. I would be interested to know if anyone has any further info or if the iid tool can be used to see this info |
I generally use my car for longer runs, so I assume that DPF regeneration is taking place in the background without my knowledge but, like Buckster, it would be interesting if there was a log somewhere in the ECU which the IID tool could interrogate.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
At last service my garage said that ash or whatever was at 33 grams and a forced regen was needed. There was no dash warning. But they saw the figure on some gizmo or other and said regen would be done with laptop plugged in...
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
Passive DPF regenerations ( when the DPF is hot enough) does not lead to oil dilution.
It can in live values. There is a thread or two on FF forum which shows something like Non Continuous Soot......i'll try and dig it out for you.... https://www.fullfatrr.com/forum/topic49020.html?highlight=dpf https://www.fullfatrr.com/forum/topic48068.html Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
With living in Orkney I typically do 5000 miles a year with only do runs of 7 miles, although at least 3 times through the year I travel to Inverness or beyond which may help things with a minimum of 120 unbroken miles, but after 2 1/2 years I've not had any issue's whatsoever (that'll have gone and done it.....). The only thing I have noticed is a few weeks ago I was reversing onto my drive when I smelt a paraffin type smell so I immediately went a drive for about 30 minutes keeping the rev's at about 2800 odd (no not 100mph, I chose a lower gear ![]() Here is a screenshot of a recent iiDTool showing all I could find to do with the DPF, and it all looks good unless I'm interpreting it wrong. Is there a way to get the actual regeneration counts? Can anybody confirm if these value's are ok or not? (Edit: just re-read taking more time and read there are no regen counts, only last time it happened ![]() ![]() 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
You need "Non Continuous Soot Mass" to show DPF volume.
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154 ![]() ![]() |
My Truck Isuzu 6 wheeler does a regen at least twice a week, it sometimes begins when ticking over say wheel loading truck, as above i also get a smell of paraffin being burnt, however the engine speeds up during this process, i do get notice on dashboard saying DPF Regen in progress, |
Gjlatz Member Since: 01 Mar 2019 Location: UK Posts: 40 ![]() ![]() ![]() |
Hello all, I was reading this with some interest regarding DPFs.
