Home > General > Snapped crank 2019 sweepstake
Page 1 of 5 12345>
OvalAutos
First snapped crank of 2019 Sad
This is what happens if somebody forgets to fit an oil filter Shocked
We're running a sweepstake on how many 2 piece cranks we expect to see this year in our workshop. The rule is simple; just reply your guess and we'll let you know the correct number by next Christmas. To keep it fair, I'm not going to give a running tally. So you can enter anytime between now and December.
The prize? A free timing belt change or, if you don't need that, something of equivalent value. Thumbs Up Joe
Post #572607 Tue Jan 08 2019 5:20pm
Buckster
I will go 35, hopefully mine not being one of them Rolling with laughter 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #572610 Tue Jan 08 2019 5:34pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
What do you mean by “Forgot to fit an oil filter?”
So someone serviced a vehicle. Drained the oil and removed the old filter and then topped the oil up without fitting a new filter?
How is this even possible? Shocked
Post #572612 Tue Jan 08 2019 6:46pm
Stevepd
I’m going with 11.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #572622 Tue Jan 08 2019 9:24pm
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I think around 14 Rolling Eyes
Post #572624 Tue Jan 08 2019 9:34pm
skid1963
17
Post #572626 Tue Jan 08 2019 9:56pm
Brit Plumber
I'll go with 12!
Any chance of a close up of the sheared surface out of interest. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572629 Tue Jan 08 2019 10:04pm
OvalAutos
If you look where the arrow is pointing, you can see that the main bearing shell has turned. This cut the oil feed to that journal, which caused the crank to fail and also feeds the #2 big end.
 Joe
Post #572657 Wed Jan 09 2019 9:37am
Brit Plumber
Thanks for those interesting photos, what age was the vehicle? Is it repairable with a new crank or is it beyond economic repair? 2019 5.0 SC SVA (Current)
Post #572660 Wed Jan 09 2019 12:20pm
Bill Portland
I'll try my luck with 9 Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #572675 Wed Jan 09 2019 2:11pm
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I will go with 13, as it will definitely be unlucky for some! Just hope I am not one of them Sad
Steve
Post #572684 Wed Jan 09 2019 4:48pm
drdelrrs
Cheeky to ask but how many did you see in 2018 across the JLR range?
For your business alone I'll go for 7.
Post #572695 Wed Jan 09 2019 8:38pm
Post #572700 Wed Jan 09 2019 9:22pm
Stevepd
That’s the first one I’ve seen a picture of. Can you imagine the force that tore that lump of metal Shocked
Post #572706 Wed Jan 09 2019 10:32pm
Snow White
I'll take 25
Two a month plus an extra Rolling with laughter RRS 2012 HSE Lux Alive stage 1 remap. timed heater, General Grabbers.
D3 with BAS & general grabbers (gone)
Defender with 3 winches and other subtle mods (gone)
Post #572784 Thu Jan 10 2019 7:42pm
Page 1 of 5 12345>
