Home > General > Rear Doors - Unlocking Problems
knwatkins
Hi guys, I have an issue with both rear doors not unlocking from the inside unless the little lock button next to the door handle is pushed.
Here is a summary of the problem:
- both doors lock, unlock and open fine from the outside
- when I drive off, the doors lock and the lock buttons next to the handles trigger
- when I stop, the front doors unlock but not the rear ones (the internal handles do not open the door)
- if the passengers press the lock button next to the internal handle, the handle can then open the door
I assume this isn't a latch problem as the doors lock and unlock fine.
Do you think this is an issue with the pull cable or handle/switch mechanism? Kev
Post #572609 Tue Jan 08 2019 4:31pm
Brit Plumber
Could it be child locks? Has it only just started this or did you buy it like that? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572628 Tue Jan 08 2019 8:59pm
knwatkins
Child locks are definitely off. It's always happened since I've bought the car (used).
I suppose I could turn off the drive-away locking as a work around, but it would be good to resolve the root cause. Kev
Post #572650 Tue Jan 08 2019 11:22pm
Marcpope
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
Just wondering, did you sort this issue? I've got the same issue
Post #582874 Sun Jun 23 2019 8:17am
Drive away does not activate deadlocking.
It could be electrical or weak latch
Post #582877 Sun Jun 23 2019 10:02am
knwatkins
This was fixed through replacing the latches in the rear doors. Kev
Post #582922 Mon Jun 24 2019 5:16am
