Home > Maintenance & Modifications > Low power from Alternator?
Panoramix
Italy 2009 Range Rover Sport TDV8 HSE Java Black
Hi all.
I bought an L320 TDV8 MY2008, and these are the first driving days Smile
This morning while I driving I saw on the Radio the "Low battery mode" message, so I went into the hidden menu for check the voltage.
at the minumum, (<1000rpm) the voltage is 11.5/12.0V above, it goes on 12/12.5.
Checkd also trought the Altox FBH app and I've the same values (approx)
any advice please?
Post #572535 Mon Jan 07 2019 6:57am
Bardley
Does it compensate when you load it with Heated windows and blower motors etc? You should see a fluctuation, then stability.
What's your battery history? Known new one of good rating/spec? 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #572537 Mon Jan 07 2019 8:02am
Panoramix
The battery is brend new, Bosch S5 100Ah.
The blower and the rear heater windows was on, I don't tried to turn it off. Embarassed
I can try this afternoon Thumbs Up
Post #572539 Mon Jan 07 2019 8:08am
Bardley
With a new battery, you should be seeing a change in volts when switching the loads in and off.
12.5v sounds low when having those running. 2011 MY D4 HSE
Post #572546 Mon Jan 07 2019 11:19am
garrycol
Australia
The battery is just a bit down and the car's system is reducing the electrical load - one of the first things is low power mode in the radio, if the battery gets lower the sound of the radio will be muted.
Simply give the car a good run and all should be good.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #572547 Mon Jan 07 2019 11:41am
gogsy1956
I would expect to see around 14.5 V with the car at tickover and no extras running, but I would use a voltmeter direct on the battery for readings. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #572562 Mon Jan 07 2019 6:01pm
Bardley
14v plus..
As above, with engine running 14v plus is what you should be seeing. Be aware that a faulty Alternator can take a battery with it when it fails.
There's usually little warning that it's about to go, and this may well be your heads up. Get a meter on the battery and check the running voltage with a load (fans/heated seats and screen etc.), and also off. Watch the meter as someone switches for you. 2011 MY D4 HSE
Post #572570 Mon Jan 07 2019 8:41pm
garrycol
Australia
The voltage in the system will only be up around 14v for a short period soon after start - when the alternator has put power back into the battery from the start the alternator will lower voltage to around 12.5-12.8v if electrical loads are normal - sounds all normal for a battery slightly down - as i said go for a good drive and all should be good. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #572574 Mon Jan 07 2019 10:06pm
Panoramix
One day after this post, battery light on dashboard for alternator failure Big Cry
Replaced Thumbs Up
Post #573761 Thu Jan 24 2019 9:03am
