Home > Maintenance & Modifications > Best Screen wash and wiper blades |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I`ve used Decosol as long as I can remember. I`ve tried all sorts over the years but always stuck with Decosol! Steve. |
Sun Jan 06 2019 7:53pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 908 |
Use Gtechniq G5 or Rain X on your screen. The water blows off. An occasional flick wipe with the wiper is all you need at lower speeds. I have been using it for years & don't know the last time I used screen wash or replaced wiper blades. The only annoying thing is when the car comes back from service they leave a bottle of screenwash in the car as they cant top it up |
Sun Jan 06 2019 10:41pm |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
I got some of that but haven’t used it yet! How’s it best applied? Cheers Laurence. |
Sun Jan 06 2019 11:44pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
I use Halfords' screen wash, usually the -10degC one. Seems to clean well.
Mon Jan 07 2019 10:28am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
THe Halfords stuff always used to goto jelly like in the bottle to clog the pipes
Mon Jan 07 2019 12:03pm |
Make sure your screen is clean. You can clay bar it & wipe with panel wipe. Give the wiper blades a clean too. This may be a bit OCD & you don't have to do this but the main thing is to make sure your screen is clean.
Mon Jan 07 2019 12:11pm |
I've never been a fan of rainX
Mon Jan 07 2019 12:28pm |
Been using it for years and never had a problem. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Jan 08 2019 4:23pm |
How do you find the Bosh blades? They work well for me but I get annoyed as the driver side just touches the A pillar at the end of its stroke and makes a tapping noise. The reason appears to be the cap on the end which makes it wider than the original. When I get chance, I need to see if the cap is practical or simply for aesthetics. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Tue Jan 08 2019 9:18pm |
Unipart screenwash is good in my experience and bosch blades seem to last reasonably well. |
Tue Jan 08 2019 9:43pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Personally I found the Bosch ones crap and noisy so binned them and fitted some Michelin Stealth one's instead.
Tue Jan 08 2019 9:59pm |
Maybe you had a bad pair, or perhaps I've just been very lucky with the last half a dozen sets of bosch's ? Quietest I've ever used and no smearing. Downside is they can lift a bit if going 3 figure speeds. |
Tue Jan 08 2019 10:03pm |
You need to clean your screen properly before applying anything or deciding on screen wash.....using 0000 wire wool. It`ll be like a new screen. Steve. |
Wed Jan 09 2019 12:28pm |
MrGimper Member Since: 05 Jun 2016 Location: Andover Posts: 57 |
+1 for Bosch Aerotwin blades. Just fitted another set to mine for the MOT. Never had an issue. Even managed to get Halfords to price match Amazon (they priced £19 per blade and matched to £13 per blade) |
Thu Feb 07 2019 6:46pm |
