Home > Faults & Fixes > 2010 Range Rover Vogue V8 3.6 Help
Splinters
United Kingdom 2010 Range Rover Sport TDV8 Java Black
Anyone have any Idea what the prolem is Codes listed below, Car was fine coming round the M25 the other night, next morning wife drove kids to school and brought it back in restricted mode, loads of white smoke coming out of the exhaust rough running/idle (like misfire). Rac called out diagnostics reveled a split intercooler hose which he repaired, however whn he replaced the hose the fault persisted.
Codes reading now:
P007F Charge air cooler temperature sensor Bank 1
PO10F Mass or volume air flow sensor A/B Correlation
PO102 Mass or volume air flow circuit low input
PO10A Mass or volume air flow B circuit
PO10036 Mass or volume air flow circuit
PO241 Turbocharger/supercharger boost sensor -b circuit low
POOA3 Charge air cooler temperature sensor Circuit High bank 2
PO237 Turbo/supercharger boost sensor A - circuit low
POO7d Charge air cooler temperature sensor - circuit high bank 1
Any ideas chaps? things to try?
Thanks,
Dave
Post #572417 Fri Jan 04 2019 8:33pm
ilard
I am not sure, and these codes and this scenario could well be the exact same on a Sport, but be aware there is another forum for full fat Range Rovers at https://www.fullfatrr.com L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #572423 Fri Jan 04 2019 9:08pm
Splinters
Hi Thanks,
I will post over on that forum
Dave
Post #572424 Fri Jan 04 2019 9:30pm
