Home > Maintenance & Modifications > Heater not blowing hot. 55 plate rrs
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Hi all, any idea why the heaters are not blowing hot? The heater matrix flow and return are hot so its not blocked.
When i turn the temp gauge i can hear the change in pitch on the fan so something is definately moving.
Im guessing maybe a damper sticking or summit.
Is there an easy way to get to the dampers or checks to do?
Any ideas.
Kind Regards
Gareth
Post #572400 Fri Jan 04 2019 5:20pm
riverblanche
looks like the same issue over on D3 in the "technical D3 section" worth having a look at,
possible Solenoid or blender motor, sadly thats as much as I know.
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #572401 Fri Jan 04 2019 6:15pm
Disco_Mikey
Are both sides the same temperatures?
Post #572412 Fri Jan 04 2019 8:05pm
looneyfitter
Hi, yes both sides seem same temp. If i turn Aircon off then it definately gets warmer. DT accross the flow and return is narrow so dont think its blocked heat ex
Post #572427 Fri Jan 04 2019 9:41pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Sounds obvious, but check that your pollen filter isn't blocked. If the fan can't blow through it, then no heat !
(I know, because I had the same problem Thumbs Up )
Post #574080 Tue Jan 29 2019 7:23pm
