Home > Maintenance & Modifications > LED bulbs / headlamps / conversions..?
RUSK
I'm looking for opinions or experiences with LED bulbs or LED conversions for a 2008 TDV8...
I don't want to mess up the system with error messages etc, but if there's a decent conversion kit or some good bulbs that could improve the lighting and look of the car, I'd be keen to know about it!
Post #572404 Fri Jan 04 2019 6:58pm
Brit Plumber
With headlamps you will need to replace the whole unit not just the bulb as it’s now an MOT failure to have LEDs in a unit not designed for them. For things like puddle lights etc you’re fine. For fog lights I’ve found that LEDs aren’t as effective as halogen but they are good for indicators (orange for clear indicators). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572458 Sat Jan 05 2019 4:46pm
Bardley
As above, it's the reflectors in the light units that are not designed for LED light spread. The light scatters, and that's what causes the dazzle for oncoming cars.
Best to change the whole unit and stay within MOT regs.
The world seems to have gone mad for the brightest possible light in headlamps at the moment. Fine while you're behind the light, but awful facing it.
The OSRAM bulbs get good remarks on the D3 forum. May be worth trying those first. Not cheap tho'. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #572480 Sun Jan 06 2019 8:20am
RUSK
Thank you both - this forum is SO useful for advice and info.
I definitely want to stat MOT compliant, and I'm not really looking for super-dazzling lighthouse lamps... but I drive a lot of lanes and unlit roads, so I think an improvement (if possible) is a good idea.
I'm now hunting for a good replacement unit... (I'll be back soon with more questions I'm sure Shocked )
Also, PUDDLE LIGHTS... I don't seem to have them?
Post #572484 Sun Jan 06 2019 10:57am
Just stick Osram Xenarc Nightbreakers / H7 Nightbreakers in and ensure the beams are correctly sdjusted. The original RRS TDV8 headlights are excellent with decent bulbs and correctly set up units. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #572509 Sun Jan 06 2019 6:46pm
