Home > General (L494) > Is it ok to use my Spare Tyre?
Bensrrsport
I have a Full-Size spare wheel with an unused Conti Tyre - manufactured in March 2015. Rather than buy 4 new Conti tyres, what do you think about buying 3 and using the spare?
Post #572254 Thu Jan 03 2019 12:37am
Lindab
From Continental website- 10 years
Continental is unaware of any technical data that supports a specific tire age for removal from service. However, as with other members of the tire and automotive industries, Continental recommends that all tires (including spare tires) that were manufactured more than ten (10) years previous be removed from service and be replaced with new tires, even when tires appear to be usable from their external appearance. Even if the tread depth may not have reached the minimum wear-out depth. Vehicle manufacturers may recommend a different chronological age at which a tire should be replaced based on their understanding of the specific vehicle application; Continental recommends that any such instruction be followed. Consumers should note that most tires would have to be removed for tread wear-out or other causes before any proscribed removal period. A stated removal period in no way reduces the consumer’s responsibility to replace tires as needed.
Post #572268 Thu Jan 03 2019 11:48am
Black Bess
Your car will not be worth any more with a new spare than a used one. Go ahead and use it. It will be fine!
Post #572272 Thu Jan 03 2019 12:25pm
SVR575
Of course, it is. Thumbs Up SVR 2018 in Santorini Black.
Post #572280 Thu Jan 03 2019 2:22pm
Tim in Scotland
If you are old enough, in the old days we used to rotate wheels every 10000 miles or so to have even wear all round and even LR up to recently did it for you at a service if you car came with a full size spare. With the advent of space savers or even just a can of foam this is something that has fallen by the wayside. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #572312 Thu Jan 03 2019 9:37pm
Bensrrsport
Great! Thanks for your feedback - that will save the cost of 1 tyre.
What do you think about the Continental Cross Contact LX Sport tyres?
Post #572364 Fri Jan 04 2019 11:44am
Black Bess
I am sure there is nothing wrong with them at all. A lot is down to personal preference. If you want to keep a nice set of 4 tyres the same, then the choice is obvious.
I tend to go for less expensive brands these days. All the cheaper brands are owned by the premium brands and have the same quality controls. I will be needing 4 new ones on my 2014 soon, unless I sell it. On my last car I had yokohama which were superb, but did not last long, Nexen which were great, and Barum which handled badly. I would avoid those at all costs.
Post #572368 Fri Jan 04 2019 12:04pm
