Home > Maintenance & Modifications > Part number for rear ACE bolts & seal
slinger
Hopefully somebody can help. I have searched everywhere I can for a part number for the two bolts and seals for the rear ACE pipe connections to the rear ACE unit on a MY08 RRS 2.7 ? I had the pipes replaced a while ago but the ACE system has developed a leak again. It looks like the original bolts and seals were used in the pipe replacement and they are now leaking (at least I hope it’s that and not a failed unit)
Anybody have any info on these parts?
Post #571899 Sat Dec 29 2018 12:28pm
Brit Plumber
Are the seals not installed on the pipe when new? When I did my front pipes they came with new seals (or at least I’m sure they did). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #571924 Sat Dec 29 2018 4:25pm
Disco_Mikey
Yes, new pipes come with new seals...
Post #571935 Sat Dec 29 2018 5:24pm
