Home > My Range Rover Sport > Diesel heater webasto |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8991 |
Unless you have the optional park heating, the FBH (fuel burning heater) is an entirely automatic device. It's used when the external temperature is below about 6 deg C (some are higher than that it seems) and where the coolant temperature is below a certain threshold. I.e. if the engine is cold/cool and the ambient temperature is cold.
Fri Dec 14 2018 3:04pm |
DeeWee Member Since: 04 Dec 2018 Location: Plymouth Posts: 26 |
Thank you so much for the reply. Very very helpful, I'm glad it's not a case of operator error. I was thinking how do I turn this thing on but now I know I have to buy the additional kit I will.. 👍🏻 😁 |
Fri Dec 14 2018 3:44pm |
Do a search on the forum and you should find a recent-ish thread about the kits etc. 2012 SDV6 - it's missing a couple of cylinders
Fri Dec 14 2018 6:32pm |
Sun Dec 16 2018 5:52pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
Worth checking on topix what your car is supposed to have. I just needed to buy the remote fob and it worked. Merc C220 estate Sport AMG
Sun Dec 16 2018 6:43pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
How do you know if you've got what you need to just add the fob? 2016 Black SDV8 Autobiography
Sun Dec 16 2018 7:03pm |
I can't find the the thread on the forum but there's a receiver module in the drivers side boot cubby. If you have it, then you just need the fob to transmit to it. The thread explains how to pair the fob (from memory, you just have to remove and replace a fuse). Merc C220 estate Sport AMG
Sun Dec 16 2018 7:42pm |
Here you go - http://www.rrsport.co.uk/forum/topic46822....te+fob#end Merc C220 estate Sport AMG
Sun Dec 16 2018 7:56pm |
A big thanks to all who replied with their help. |
Sat Dec 22 2018 1:48pm |
