![]() | Home > Maintenance & Modifications > Why you should NOT listen to LR's 'Filled for Life' claims |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1183 ![]() ![]() ![]() |
from the horse's mouth:
taken from the ZF 6HP26 Service Information bulletin, but guidelines are probably the same for the 8H version:
Filled for life is nonsense - my LR service document does not mention filled for life but has change gearbox fluid at 10 years or 240,000km whatever is earlier and if used in arduous conditions - such as normal city commuting is to be changed earlier - nothing filled for life - is an urban myth. 07MY RRS TDV6
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
I had the gearbox oil changed in my SDV6 at 70k miles earlier this year. The TDV8 was also changed early at a similar mileage. 2012 SDV6 - it's missing a couple of cylinders
I’m signed up to the Bodsy event on the 19th Jan. Mines on 60k but it’s 12 years old.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
You'd be surprised just how dirty the oil is, even at 60k miles... |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
I recently changed the gearbox oil on my daughters 2013 Ford Fiesta with 48,000 on the clock. Even I was shocked at the condition of the oil which we drained out!
