Home > In Car Electronics > Range Rover Sport 2005 SAT NAV Loss of GPS
green giant
I am new here and stumbled across this forum while trolling the net for a problem I have with my 2005 RRS, I apologize if this subject has been covered before !!
A red line appeared through the word "GPS" on the top left of the screen, the Sat Nav still works unless I drive on a road that doesn't exist on the Sat Nav or sometimes if the vechicle has not moved for a couple of days, then it loses itself and I end up in the middle of the North Sea. I can manually reset the position and it works again for a while. So it is somehow managing to follow the route but is not picking up a GPS signal.
Does the CD need updating? if so where is the best place to get it done?
Has anyone else had a similar problem and how did you fix it?
With most of this 2005 money pit getting renewed slowly I have another problem with the front and rear parking sensors but thats the next one to tackle after the GPS.
Cheers GG
Post #570834 Mon Dec 10 2018 4:06pm
GodivaNige
Common fault, highly likely the GPS antenna in the sharks fin has failed.
Easy cheap fix works very well. It cost me less than £10 12 months ago and still working perfectly.
http://www.rrsport.co.uk/gallery/albums/us...%20RRS.pdf
Post #570868 Mon Dec 10 2018 10:25pm
