![]() | Home > Technical > RRS oil level |
Are you following the correct procedure |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
Try This one..
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 ![]() ![]() ![]() |
Ok thanks I'll try that. |
Make sure you are not resting your foot on the throttle pedal slightly either or try putting your toe under it and lift the pedal very slightly when checking.
Should be in the owners manual |
