Home > Maintenance & Modifications > Ghetto-spec FBH remote
HughN
Wales
A quick Heath-Robinson FBH remote using modules available from eBay. The analogue to W-bus control was about £40, the rest a few £££ each. No programming. No real hassle. No neatness!
Controlled via the 433 Mhz RF remote switch, it will only start the FBH below 10 °C. The timer module switches it off after 15 mins (or via the remote).
Wiring is utter bodge and the control box lives in the driver's side 'battery box' (still needs tidying). Protected by 1A fuse wired into under-bonnet fuse box.
Only a few mA required, so shouldn't affect the battery. A £7 wifi switch is on its way to me - control via app on phone which includes timers. If I had thought about it, the indicator LED should have been mounted in the lid of the 'battery box'.
Post #570692 Sat Dec 08 2018 4:10pm
cool.
Links to the controls would be good. I little project over xmas Laughing
I know about the WBus convertor. Already in my watched list
https://www.ebay.co.uk/itm/Analog-to-W-bus...2749.l2649
Box (if not using temperature sensor)
https://www.ebay.co.uk/itm/Plastic-Enclosu...SwwkFanmaY
Post #570699 Sat Dec 08 2018 6:04pm
HughN
Wales
Hi Andy,
These are the ones I used (for no particular reasons) but there are lots of different ones out there on eBay:
The thermostat.
The timer.
The remote.
(and the FBH wire was from the Disco 3 shop)
Fuseholder, LED, etc, from local car spares shop.
The thermostat is probably OTT. My original plan was to fix the thermocouple to a water hose / engine block but I couldn't get it to reach anywhere suitable.
HTH. Don't blame me if it catches fire! Wink
Post #570702 Sat Dec 08 2018 7:14pm
Early cars e.g 2004/2005 will have a red wire coming out of the FBH connector already. So you don't need to purchase the pin, just cut the wire, allowing enough length to join to the wire going into the FBH.
Connect it to the green wire from the blue module.
Thanks. Very much. Very Happy
Post #570704 Sat Dec 08 2018 7:21pm
So I can skip the temperature sensor.
When the battery is disconnected, do you have to make it re learn the remote control ?
Post #570710 Sat Dec 08 2018 9:12pm
HughN
Wales
No, it carries on regardless.
It only needs to be in 'momentary mode' to trigger the timer and a second click switches off the timer.
Post #570712 Sat Dec 08 2018 9:25pm
Hi.
So I tested the remote Rx on its own. All good.
I tested the timer on its own. Works. Instructions aren’t great! Latched/Once the wrong way round. Relay contacts NO NC wrong way round! Buts that’s ok.
I put it all together today as the box arrived,
Did you make the link on the blue PCB?
+3°C today
When I connect + to the orange wire, the FBH makes a small noise (no heat).
When I remove + from the orange, the FBH makes a larger noise. (cool down cycle?)
The FBH seams to work ok when the engine is started.
Is yours working ok in Hi power or Lo power mode?
Does it start instantly?
Thank you
For others, the box I went for was off ebay. search Case90x70x28mm
Which is just about large enough, if you don't have the temperature module.
Post #572453 Sat Jan 05 2019 4:06pm
I got it working Very Happy
I made the PCB link. I was also not waiting long enough for the heater to start fully.
Note Jumpers J4 and J5 are fitted in the top position.
Hopefully you can see where the wires go.
+12v battery in on the thick red wire
Ground on the thick blue wire in this picture
Green to the heater
Helps if you know how to use a soldering iron, so you can tack all the red wires together
and all the black wires together.
Not too much solder if you want it to fit into the terminals
Current draw 12-14mA (most of this must be the power LED!) so it won't flatten your battery.
Post #572457 Sat Jan 05 2019 5:28pm
HughN
Wales
Hi Andy,
[Disclaimer - I broke mine yesterday!]
I didn't bridge the pcb. After double-checking with the seller, I left it as it was.
The heater starts when the orange wire is connected to +12 V . Though it isn't silent, it is a while before the full 'jet engine' effect kicks in; it stops when 12V is removed.
I'm sure you'll have done it properly anyway, but the red wire needs to be wired to a permanent live so that it is 'awake' when it gets the orange signal.
Post #572460 Sat Jan 05 2019 7:09pm
Yeah got it working thank you Thumbs Up
Which bit of yours have you broke
Tip
So those with early cars which have a Red in the fbh terminal and if you wish to fit the remote module inside the car, you can find the other end on a
Rectangular grey connector which is tucked behind the cjb bracket (behind glovebox fusesbox).
There are 2 red wires. So pick the correct one. I cut the wire.
There is also a +12v on the next pin if I need it.
Alternativly, the red wire and power is available in the boot, on the right hand side. It is taped to the loom, behind the rear light area
Post #572461 Sat Jan 05 2019 7:12pm
HughN
Wales
(I cut through a wire whilst neatening it up into a 3d-printed box attached to the FBH bracket Embarassed )
Post #572464 Sat Jan 05 2019 7:18pm
HughN
Wales
As as an experiment, I replaced the RF remote with a wi-fi switch and linked that to Google Home. Saying"OK Google, run the heater" switches it on. Wink
Post #572599 Tue Jan 08 2019 2:22pm
For those who aren't into DIY.
for pre facelift cars:
www.lr-fbh.co.uk
£125
Post #574058 Tue Jan 29 2019 4:12pm
I see someone has done a GSM SIM version (simple DIY) for £70. TXT your car to start the heater
Useful if your car is parked a distance away or out of range.
https://www.disco3.co.uk/forum/gsm-switch-...78879.html
uses GSM module
https://www.gsm-uk.net/product-page/copy-o...r-pcb-only
Post #574931 Sun Feb 10 2019 10:56am
Got some good use out of mine in March. Thumbs Up
Looks like your design has been copied (pre assembled but without timer)
https://rover.ebay.com/rover/0/0/0?mpre=ht...4117320536
Make yourself :
The blue Wbus controller has also been modified
https://www.ebay.co.uk/itm/Analog-to-W-bus...Sws~Bd8TaC
Remote
https://www.ebay.co.uk/itm/DC12V-Relay-1CH...Swgbpff-Gc
Timer
https://www.ebay.co.uk/itm/5-12-24V-DC-Inf...%3A2334524
Post #598777 Sun May 10 2020 6:46pm
