Home > Faults & Fixes > Explain this.. |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Ideally a fault code reader will help diagnose your issue here, but this could well be a Engine Coolant Temp. Sender fault.
Mon Dec 03 2018 7:22am |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Engine is the 4.2 supercharged 2005. I swapped the thermostat cause the gauge was showing a cooler engine and the old one was all split inside anyway.
Mon Dec 03 2018 5:45pm |
Check coolant temp. But bear in mind that the reading will be from the ECT.. and that may be reading erratically, so showing Abnormal Temp. on the gauge on the dash.
Mon Dec 03 2018 6:12pm |
Where on the engine is the sensor located? |
Mon Dec 03 2018 7:33pm |
Will have a look... should be a manual online. 2011 MY D4 HSE
Mon Dec 03 2018 7:38pm |
And anyway - I just went out to put the code reader on it.. I started it up and it got up to temp (on the gauge) and it ran ok. No fan coming on and gauge stayed steady.
Mon Dec 03 2018 7:59pm |
It will be air locked, did you follow the bleed procedure after changing the stat ? |
Thu Dec 06 2018 12:40pm |
Sorted. Although not without agro.. As ours has lpg some of the pipes were in the way of the sensor and when I lifted the retaining clip it sprung off and dissapeared into the engine bay. It took a rather long time to locate it.. As for the obd port, the fuse was popped. |
Thu Dec 06 2018 1:16pm |
How can I tell if its air locked?
Thu Dec 13 2018 7:56am |
