Home > General > TDV8 Exhaust upgrade?
RUSK
I’m considering an exhaust upgrade due my 2008 TDV8 - what are the best options to release the lovely V8 soundtrack? Muffler deletes or a full system? Any recommendations for something off the shelf?
Post #570141 Thu Nov 29 2018 9:40pm
First thing to do on a turbodiesel is to remove the cats - this will allow the turbo to spool up quicker and give you a bit more low-down power.
It won't do much for the sound though, and removing the mufflers might introduce a drone which may be unbearable at cruising speeds. --
Post #570147 Thu Nov 29 2018 10:04pm
Camelrock
In the uk it would also fail the MOT !
I contacted griffin exhaust a few weeks ago who said they’d do a cat back system for around £500 so ordered but they’ve never got back to me . To be fair I haven’t chased them to find out what’s happening 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #570177 Fri Nov 30 2018 10:14am
Disco_Mikey
Straight through cat back system Thumbs Up
Or, decat and Centre silencer deleted (my preference Mr. Green)
Post #570228 Fri Nov 30 2018 7:53pm
RUSK
MOT friendly?
Post #570245 Fri Nov 30 2018 10:16pm
Disco_Mikey
Can't fail it if they can't see it...
Post #570258 Sat Dec 01 2018 11:20am
Would it still pass the emissions test? 2012 SDV6 - it's missing a couple of cylinders
Post #570260 Sat Dec 01 2018 12:26pm
Disco_Mikey
On a diesel, yes. A diesel only requires a smoke test for an MOT. A healthy diesel would pass witn or without a cat
In fact, my readings without an EGR and without a cat were lower than with them both fitted...
Post #570264 Sat Dec 01 2018 2:28pm
richardch
Switzerland
Im sorry but on a diesel in almost 2019, removing the cats`is a dumb on dumber thread ?
Post #570461 Tue Dec 04 2018 9:42pm
Disco_Mikey
Any reason why?
Post #570473 Wed Dec 05 2018 7:19am
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
My first thoughts would be that you have modified your car so would need to inform the insurance company who clearly would not agree with an illegal modification. if you then proceeded you would invalidate your insurance and be liable for a considerable fine if caught. That could easily happen in an accident where you were totally innocent.
I am assuming here that all this is hypothetical and not advice.
Are you insured if you have had the EGRs blanked and not declared it?
Post #570489 Wed Dec 05 2018 10:23am
Disco_Mikey
Are you insured if you fit 275/45’s in place of the standard 40 profile?
How about fitting non-genuine parts?
LED bulbs? Black badges?
Thankfully, my trade policy covers me for modifications Wink
Post #570520 Wed Dec 05 2018 8:45pm
LandPhil
In most of the examples you use you would be well advised to inform you insurance company or you may not be covered.
The issue with cats, DPF or even EGRs is they are part of the emissions control system and the new rules , as you will well know, are if they are fitted to the car at manufacture they must be working to pass the MOT.
If I fitted 275. 45.20s Iwould definitely inform my insurance company.
Post #570524 Wed Dec 05 2018 9:19pm
Disco_Mikey
Agreed. Any modifications should be declared, regardless of what they are...
The emissions rules have always been like that. However, if they can’t see it, they can’t fail it. My D3 passed 5 MOTs with no cat and no EGR valves...
Post #570550 Thu Dec 06 2018 7:53am
Tyrefitter
As DM says,,cannot see it cannot fail it,,how can we as testers see if a egr has been blanked off,we can fail if the cat or dpf has been cut open unless the customer gives us proof it has been cut open for a reason,,easy solution is to put a heat shield covering said item then we cannot see if its been tampered with. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #570552 Thu Dec 06 2018 8:28am
