Home > Technical > electric tailgate
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
electric tailgate
Hola,
RRS 2014.
Last week the normally fine tailgate opened from the fob and when pressing the drivers side button and the tailgate button.
Now this week when pushing either of the 3 options it only clicks open but doesn't raise.
When pushing the buttons to close it, it does as it should.
Any advice? i am sure i read somewhere that you can set the height the tailgate opens to by a manner of opening it to desired height and a mixture of button pushing?
cheers in advance. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #570433 Tue Dec 04 2018 5:32pm
Autobiography1969
sound like you have a tailgate memory issue..
I did this on a 2012 and it works..
you just need to lift it from low down..
&t=0s&index=34&list=WL
Good Luck.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #570438 Tue Dec 04 2018 6:02pm
Mine does this at random times. It's very annoying. Sometimes it opens fully first time, other times it clicks open and stops, sometimes it opens a few inches and stops. Another example of a solution looking for a problem - manual tailgates are fine! 2012 SDV6 - it's missing a couple of cylinders
Post #570440 Tue Dec 04 2018 7:07pm
Actualy tells you in Owners Manual how to do it, that's if a RRS2 is the same method.
Manually position the tailgate where you want it when open, hold it in position for at least 3 seconds, then press and hold the button on the tailgate until you here a "beep" from the car, job done.
Post #570455 Tue Dec 04 2018 8:12pm
